Pat Bowen Posted July 25 Report Share Posted July 25 I am new to the Unitronics line of products. I have a piece of equipment that is built on a Unitronics controller and PLC. I am getting ZERO help from the machine manufacturer. I am having an issue with the machine and need a copy of the PLC programming to further my troubleshooting. I have downloaded the UniLogic software to a Win10 PC. I have been able to establish a connection with the Unitronics device. However, when I attempt to upload the existing programming, I get the following error: "The project in the controller cannot be uploaded. This is because the project was downloaded without an Upload option.". The UniLogic version on the PC is 1.33. The version of UniLogic showing in UniApps on the machine is 1.28. Any help/tips would be greatly appreciated. Thanks in advance for your time! Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted July 25 MVP 2022 Report Share Posted July 25 17 minutes ago, Pat Bowen said: This is because the project was downloaded without an Upload option Without the upload option enabled when the project was last downloaded you will be unable to obtain a copy of the project in this way. Most PLC software is set up this way to protect intellectual property. 1 Quote Link to comment Share on other sites More sharing options...
Pat Bowen Posted July 25 Author Report Share Posted July 25 Makes total sense. This is what I assumed but wanted to ask anyway just to be sure. Thanks again so much for taking the time to answer! Quote Link to comment Share on other sites More sharing options...
