  • 3 weeks later...
Hello,
V350/V570 are supporting Enfora Modem, if you have problem to communicate pleasemake a little test:
Step1:
Poweroff the modem>Insert your GSM SIM Card>connect the modem to your PC byusing the full 9 pin cable (P/N MJ10-22-CS28)>power on themodem
Step2:
OpenVisiLogic>Modem Services> Verify the setting as below (including PIN codeif there is any)>and click on Prepare PLC-side modem.
Waituntil it finish initialize.
Ifeverything is ok, unplug the full 9 pin cable from the PC and modem, thenconnect the special adapter MJ10-22-CS72 + 4 wire cable to the modem .
Thesecond edge to the PLC's COM2 set as RS232.
Step3:
Openthe ladder>put direct contact as SB2 and add the Com init from the COMmenu> click ok and download to the PLC.
Whenyou finish to download this basic program please power off the modem and thePLC and turn them on after 3-5 seconds.
InVisiLogic go to on-line mode and check the status of SB82 (1=init /SB83:1=fail).
i hope it helps!
