Cannot change "Run as a display" back using "Return to USP" when should
Hi everyone
I hope that someone can help me
During a validation of one our PLC unilogic, I pressed a button with the tag " run as a display" then the system reeboot and shows the followings screens.
And I couldn´t return to my PLC  program.
The button return to USP is disable and I try to reset the PLC, recharge the firmware  but continuos in the same situation
Help me.
Thanks in advance.
pro-T4kMgm4i.thumb.jpeg.264d33f21b58cf99649d86afe383da19.jpegpro-Klfiq6uN.thumb.jpeg.c4fb9f59e4341397baa290fbf2d6ed1c.jpeg
  • NoamM changed the title to Cannot change "Run as a display" back using "Return to USP" when should
