show decreasing clock hour/min/sec on the hm hey guys
  • MVP 2022
Please also note that if you are simply showing a countdown for people to observe, Kratmel's answer is perfect.
But if the 130 is actually controlling the fan's run time, the ideal method of doing this is for the timer to be linked to the fan control output with a little ladderwork.  Having 2 separate timers running for essentially the same thing will work, but is not ideal in case the fan output is turned off for some reason.  In that case the timer will still be implying the fan is running.
cheers, Aus
