Graham Witkowski Posted October 17 Report Share Posted October 17 Hello I'm using a Samba 43-J-R20 with a encoder. 250PPR & 250mm Circ wheel - so 1 PP/mm I am look for help with writing a program to act as a techometer. I need it to display distance as well as meter per min. Has anyone created anything similar I could have a look at please? Thanks in advance Quote Link to comment Share on other sites More sharing options...
DanT Posted October 17 Report Share Posted October 17 Hi; In VisiLogic, Hardware setup, when you define a High Speed Input, right below that is Frequeny Measurement, select 100ms, 500ms or 1000ms , define an MI, and then create your tach using this data DanT Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted October 17 MVP 2022 Report Share Posted October 17 Please see this topic and modify code for your setup Quote Link to comment Share on other sites More sharing options...
