Emil Jacobsen Posted October 4, 2011 Report Share Posted October 4, 2011 HI What is the easiest way to detect a change in an MI? What I need is a bit to be set whenever an MI changes its value Quote Link to comment Share on other sites More sharing options...
Emil Posted October 4, 2011 Report Share Posted October 4, 2011 hou need ot make a buffer - another MI. At power up or start specified process, you store the value of MI in thhis buffer (ordinary Store direct). Next scan (net before the one described above) you compare the value of MI with the one of the buffer (Compare function - not equal) and if this is true, activate a bit. Then, the next net (as desctibed above, you will store the curent MI in the buffer. This way the next scan you can compare and locate changes again. Quote Link to comment Share on other sites More sharing options...
linxchas Posted October 7, 2011 Report Share Posted October 7, 2011 Quote Link to comment Share on other sites More sharing options...
