For Each Loop : real to data table error
pascal
I've made a routine - a for each loop - with a list of tags including buffer tags and real tags.
I want to copy one tag (real) into a data table with the instruction Set DTI column value
B = real value C= real value of the structure  current item
after compiling I get a lot of errors....
as you can see, 118 error's........
But I found a solution -> store the real tag of my structure into a local real tag and then put this tag as value to store (C), then I have no error's.....
Good to know, so I wanted to share this with thee community (or maybe this is a bug?)
  • 4 weeks later...
@pascal Indeed, this was a bug!
Thanks for reporting, a fix should be included in an upcoming version 🙂
