Seasons greetings to all!
One for the creators in particular.
Would it be possible to have a minimum and maximum put into the Linearisation function so that I don't have to do extra equations "externally" to achieve this?
Nearly all the Linz I do are only active over a certain range, and I have to write compares to set the high or low figure that over-rides the output once the input ranges are exceeded either way. It would make things vastly easier if it could be done within the Lin
