gregory Posted May 12, 2012 Report Share Posted May 12, 2012 I insall new VISILOGIC 9.4.0 + update I tried to print some ladders. Program respond when I choose printer ........................" RUN TIME ERROR 380" after click OK ................ " RUN TIME ERROR 440" I use 64 bit win7 configutation. Did you also have similer problem. Is it bug or I make some mistake. Kind Regards. Gregor Quote Link to comment Share on other sites More sharing options...
gregory Posted May 25, 2012 Author Report Share Posted May 25, 2012 Hi, i solved the situation with reinstall again. Gregor Quote Link to comment Share on other sites More sharing options...
