MakeFiks Posted November 22, 2013 Report Share Posted November 22, 2013 I have setup a UniOPC server and want to communicate between that and a Mitsubishi Q-PLC. I use Linkmaster to connect between, but i need a software that can generate the Tags needed to get data from my OPC. The PLC is a Vision 130 with ethernet card. What can i use or is it a searcret way to make this work? Looking forward to your suggestions! Good morning from the north! Quote Link to comment Share on other sites More sharing options...
