Radim Posted March 28, 2018 Report Share Posted March 28, 2018 Hi, I'd like to download data from Samba, I am using ethernet connection. DataXport is in listen mode. When connection is estabilished (socket3), DataXport stops with this: " run-time error 13 : type mismatch". I tried call mode also and it worked. The data table was the same. Any ideas? Thanks Radim Quote Link to comment Share on other sites More sharing options...
michaeldowning Posted May 13, 2018 Report Share Posted May 13, 2018 Please try this: Backup your project files. Uninstall Unitronics DataXport Erase the “Unitronics DataXport” folder from- C:\Program Files\Unitronics Delete Unitronics Folder in Common files C:\Program Files\Common files\unitronics Restart your PC Install DataXport Quote Link to comment Share on other sites More sharing options...
