Innov Posted March 29, 2011 Report Share Posted March 29, 2011 Hi all, Having a problem saving the calibration from loadcell unit IO-LC3 with the V350 TRA22. I perform the steps shown in the example loadcell application and when it comes to saving the calibration the loadcell command status is 0 (busy) for a few seconds before returning status message 6 Communication Error (I/O module does not exist). I performed the calibration steps separate from the saving and they work fine. I found that if I manually change (in test mode) the command status of the loadcell back to 1 then the loadcell continues to function correctly and occasionally holds the correct calibration on power down and reboot but it isn't consistent. Wondering if anyone else has had this problem and can suggest a fix? Cheers, Innov Quote Link to comment Share on other sites More sharing options...
