Matt@BAE Posted October 9, 2010 Report Share Posted October 9, 2010 I am using a v570 with expansion modules. I need a frequency measurement from high speed counters. I've been trying to use the "new" fb immediate frequency measurement based on high speed counter. It seems that this fb can only be linked to HSC0 or HSC1 which I assume only pertain to snap in module inputs. Is this doable with hscs tied to the expansion modules? Do I have to go back to my old sample the value store in a buffer find the difference etc. based on a time constant, etc. etc. etc.? Quote Link to comment Share on other sites More sharing options...
Emil Posted October 10, 2010 Report Share Posted October 10, 2010 Advanced Frequency measurement funciton operates together with HSC Reload. It can be linked only to Hardware, where Reload is supported! Quote Link to comment Share on other sites More sharing options...
