0x00 Posted January 25, 2014 Report Share Posted January 25, 2014 I have a subroutine with 7 valid nets. nets 8 through 16 are blank, no op. net 17 is the return. I would like to delete the white space and have the return be on net 8. but I cannot cut nor delete...nothing happens. Return remains way down at the bottom of a bunch of white space. a bug? or am I missing something? V9.4.0, build zero. 570 vision plc app. thanks Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted January 27, 2014 Report Share Posted January 27, 2014 Hi, Visilogic has a minimum limit of 17 nets per subroutine. Although, you can add a Subroutine Return from the Utils-->Calls menu. There aren't any improvements in performance for deleting empty nets, but if it bugs you esthetically, you can minimize them by pressing the Minus sign on the top left edge of every net. 1 Quote Link to comment Share on other sites More sharing options...
