swivige Posted February 17, 2015 Report Share Posted February 17, 2015 Hi, I have a problem with my EXF-RC15 module. I can't get connected to it using USB anymore. My computer does not recognise it and I even used another computer to check and same thing happens. The module worked well at first. The only problem I had when I received the module is that I was not able to connect to it using Visilogic through canbus, but was able to send and receive data (through canbus). Now I cannot change its program since USB is not working anymore. My PLC is Vision V130. Visilogic version: 9.7.44 build 0 Thanks. Faical Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 22, 2015 Report Share Posted February 22, 2015 Hi, Please send your EXF-RC15 project to support@unitronics.com for review. You can add V130 project for CAN access simulation. Quote Link to comment Share on other sites More sharing options...
