prebone
Modbus on UAC-02RS2 RS232 serial interface
Hello,
As of now, the two ports capable of Modbus communication are COM1 (RS485 port on CPU) and the Ethernet port on the panel.
Is it possible to use RS485 communication with the radio?
Thank's for quick response, mr Pratt!
I found in the documentation on the radio (SATEL  EASy 869) that they are programmable to RS422, I'll check further with my dealer on this.
Else I usually use modbus TCP on the ethernet port, but this time I need to go on the air.
Sorry I didn't check if modbus worked on the Uni-COM modules before ordering, I took it for granted and was fooled again. ;-)
Regards
Preben
