Hannari Posted August 29, 2015 Report Share Posted August 29, 2015 Hello. I have a program that isn’t that large but is repeated multiple times for multiple devices of the same type. I wanted to make a UDFB were I would only have to pass in a struct of the device but because I have to use Negative and Positive Transition Contacts many time throughout the program then I have had to have each device in its one Region. Isn’t there a way to use PTC and NPC inside UDFBs? Regards Quote Link to comment Share on other sites More sharing options...
