TODDSTER Posted September 6, 2017 Report Share Posted September 6, 2017 Not a big deal, but I'm pretty sure there is a typo error in the STRUCT Help topic. The Help menu image shows MI102 broken out into more than 16 bits. The function block shows a length of 10 associated with MB10, so I assume MI102 would be broken out into MB10 through MB19. Would that be correct? The image shows 32 bits possible (blue rectangle), and below it MB10 through MB32, which is obviously not a length of 10. Out of curiosity, in this example, would MB10 be the most significant or least significant bit of MI102? Quote Link to comment Share on other sites More sharing options...
