Dipak Posted September 21, 2017 Report Share Posted September 21, 2017 I have project in which I need to read the csv data file in the PLC. So what kind of function block or What is the best programming practices for this type of program? How can I read the data from csv file in to PLC? How can I write data from PLC to csv file? Quote Link to comment Share on other sites More sharing options...
TylerHPS Posted February 20, 2018 Report Share Posted February 20, 2018 Use a convert .csv to UDTF file, then load the UDTF file into a data table. Should work smoothly as long as your csv matches your data tables Quote Link to comment Share on other sites More sharing options...
