CanRookie Posted February 6, 2018 Report Share Posted February 6, 2018 Hello, I'm working on my first CANopen project where a frequency drive is controlled using the Vision 1210. However i can't seem to figure out how i can start this drive. According to the CAN Bus Operation PDF i should be able to control the drive using PDO 1, as it's default mapping is the control command register. To start the drive bit 0 from register 2000 must be set. but how can i set bit 0 using canbus? CAN Bus Operation.pdf FENNER_QDNEO_S2-S3_CANopen 2.00.eds Quote Link to comment Share on other sites More sharing options...
