Knight Posted February 20, 2020 Report Share Posted February 20, 2020 Hi all, I have a Visilogic program running in a V700 that is sending Direct Mail Content emails successfully. I would like to be able to send Indirect Mail Content with some descriptive text accompanying the content but this Indirect Mail Content option only allows me to send 1x MI. Can I configure to send something like the following: Plant Throughput: xxxx m3 Waste: xxxx m3 Total use: xxxx m3 The above xxxx's are MI's Is this possible using String to ASCII, Part of String etc blocks, or do I need to have an SD card and export a data table as an attachment. V700 is very remote and hoping not to have to travel to install card..... Any suggestions would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
