TODDSTER Posted July 18, 2011 Report Share Posted July 18, 2011 The following captures are from the documentation on the website. Can anyone tell me which is correct, 256 or 65536? This is from the V350 comparison chart This is from the documentation for the V350-35-TA24 Thanks, Toddster Quote Link to comment Share on other sites More sharing options...
DonM Posted July 18, 2011 Report Share Posted July 18, 2011 Hi toddster, I believe firmware changes were made to enable 16-bit (65536) color. The documentation for the V350-35-TA24 probably requires an update. "From VisiLogic 9 on, all images will be 64K colors (16-bit)" Source: http://www.unitronics.com/data/uploads/VisiLogic_Software_New/VisiLogic%209%202%200%20Version%20Changes.htm Best regards, Don. Quote Link to comment Share on other sites More sharing options...
