john Posted September 10, 2010 Report Share Posted September 10, 2010 HELP! How does one 'exit a variable' while it is active on a V130 screen, ... via ladder logic, not the keyboard? According to the 'V120 and V130' topic page in the help manual: "If a Legal Entry bit is defined, SB 94 does not turn ON if the entered value is out of range. The keypad stays on screen until a legal value is entered. You can use SI 45 in conjunction with a Compare function to exit the variable." How is this done? Quote Link to comment Share on other sites More sharing options...
