papouchka Posted March 2 Report Share Posted March 2 Hello, As part of an industrial project, I need to use the MQTT protocol for data sharing. I saw in the configuration that the Unistream PLC offered several secure transfer options. For each option, it says MQTT/SSL. I'd like to be sure that under the term SSL is actually TLS version 1.2 and not the old SSL. Can anyone confirm this? Thank you. Quote Link to comment Share on other sites More sharing options...
