Damian Posted October 19, 2011 Report Share Posted October 19, 2011 I am using a V120-22-T2C. It is communicating on Comm2 by way of RS485 to a single slave. The distance is very short (less than a foot) and terminating resistors are enabled on both ends. It has been working fine (flawlessly) on 24vdc. I had to switch to 12Vdc power, and now the comms will not work. Even if I put it back on the same power supply, an go off the 12VDC taps instead of the 24VDC taps, it will not communicate. It only works properly on 24VDC. Why will the RS485 not function properly on 12VDC? Quote Link to comment Share on other sites More sharing options...
Damian Posted October 19, 2011 Author Report Share Posted October 19, 2011 My appologies. It is the slave that is causing the issue. If I power the V120 with 12VDC and power the slave with 24VDC everything works fine. Quote Link to comment Share on other sites More sharing options...
