ErwinKempenaar Posted May 17 Report Share Posted May 17 Hello, Unilogic version: 1.36.63 Hardware: USC-B10-T42 I am trying to fill a table with data received from an periodic modbus Read Holding Registers(3) operation. The data consists of 255 UINT16 datapoints. Because of the limit of 250 bytes I had to split it up into 3 different arrays. But I cannot find a function that could be used in a foreach or for loop to populate a indexed data table one column at a time (it's not possible to use an index iterator in a struct). I have tried to use a struct variable in the modbus operation directly (Via Add new struct) but then the values are being forced back to 0 and for some reason not copied into the table via the "LF: Insert Row to DTI" function. Kind regards, Erwin Kempenaar Link to comment Share on other sites More sharing options...
