graatje Posted September 16, 2010 Report Share Posted September 16, 2010 What's the most convenient way to enter a time with the format hh:mm:ss by using the keypad. First I made on the screen 3 displays (variable number) separated by a semicolon, this doesn't look nice. Is it possible to do it easier? I thought I could use the UTC variable, but I only want to entry the time and not the date. In my program I need to entry and also display several times in the format hh:mm:ss. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Phil Salkie Posted September 16, 2010 Report Share Posted September 16, 2010 Using three variables is exactly how I do it - if you use a fixed width font, it can look pretty good. Quote Link to comment Share on other sites More sharing options...
