Marsupilami Posted January 2, 2012 Report Share Posted January 2, 2012 Hello, and hapy new year. I try to program a Drum, which synchronized every 24 hour, at 10 a clock, with the RTC. (for example: Sommer/Wintertime) But the program have a mistake. Every second day the Drum runs one hour forward What is my mistake? Quote Link to comment Share on other sites More sharing options...
Petros Posted January 5, 2012 Report Share Posted January 5, 2012 Hello, and hapy new year. I try to program a Drum, which synchronized every 24 hour, at 10 a clock, with the RTC. (for example: Sommer/Wintertime) But the program have a mistake. Every second day the Drum runs one hour forward What is my mistake? Quote Link to comment Share on other sites More sharing options...
Petros Posted January 5, 2012 Report Share Posted January 5, 2012 Hello, and hapy new year. I try to program a Drum, which synchronized every 24 hour, at 10 a clock, with the RTC. (for example: Sommer/Wintertime) But the program have a mistake. Every second day the Drum runs one hour forward What is my mistake? There might be a problem with SB150. Try setting it ON and OFF by a command (it could be an MB within the drum sequencer) and not directly in the net. Keep us posted and good luck. Quote Link to comment Share on other sites More sharing options...
Marsupilami Posted January 11, 2012 Author Report Share Posted January 11, 2012 There might be a problem with SB150. Try setting it ON and OFF by a command (it could be an MB within the drum sequencer) and not directly in the net. Keep us posted and good luck. The problem is not solved. I start SB150 with a MB (power up, set) or otherwise with a toogle bit from a MB. Quote Link to comment Share on other sites More sharing options...
