Raymond Santiago Posted February 27, 2012 Report Share Posted February 27, 2012 Hi, Does anyone have an idea on how to reset the Configuration Permission of Component Services OpcEnum? I accidentally applied the changes before I can choose the option "The system account" in Identify tab. Before I could do that, I already find myself forbidden to change the settings. I am following the instruction on UniOPC manual, but accidentally made a wrong step. Is there a way to override the setting? edit the it's registry or reinstall the component? Any help will do. Thank you very much! Best regard, Raymond Quote Link to comment Share on other sites More sharing options...
LenkoTerje Posted May 21, 2012 Report Share Posted May 21, 2012 Good question. I also stumbeled on this problem once. A solution would be handy, I don't like to re-install customer systems if I don't have to. Quote Link to comment Share on other sites More sharing options...
