jules_theone Posted March 13, 2012 Report Share Posted March 13, 2012 I have a V570 running a program which receives CAN frames containing analogue data. the analogue channels are summed together and displayed on a graph. I am trying to add a SD card write module to log the signal in a table but when an SD card is present, the signal doesn't update. The program seems to be running but not everything works, is there something I'm missing? I can check the data table and it contains timed data points but the values for each channel doesn't change. Any ideas would be appreciated. Thanks. MDET-T 0.1.1.vlp Link to comment Share on other sites More sharing options...
