Rob Posted April 24, 2012 Report Share Posted April 24, 2012 Hi, Has anybody come across a problem where the attempted insertion of the mini USB cable, from my PC short circuits the HMI? I had the HMI, Snap-on and other equipment all powered up, working as it should when I went to attempt to download a small change in the program. When I touched the mini USB cable off the port, there was a short of some sort which tripped the MCB. The HMI is now dead! I;m just wondering if anyone else has come across the same issue? Thanks. Quote Link to comment Share on other sites More sharing options...
