Thomas Posted April 26, 2012 Report Share Posted April 26, 2012 Hello, I'm trying to run two steppers from a V230 with a V200-18-E3XB snapin. I'm using the example V120_Stepper_motor_with_Acc_and_Dec, My configuration: HSO's set to NPN HSC inputs set to NPN Stepper driver Vexta UDK I have wired the HSO-0 to the HSC-0 and wired V1 to COM, with this I am able to run the example, For the stepper driver they have Step (+-) / Dir (+-) inputs, if I connect HSO-0 to Step (+) and 0V to Step (-) the program just hangs. Any help would be greatly appreciated Thanks, Thomas Link to comment Share on other sites More sharing options...
sunit Posted April 26, 2012 Report Share Posted April 26, 2012 Hi how many volt SMPS are you using. I assume you are using 24v SMPS Stepper driver Vexta UDK accepts 24v pulses or 5v pulses. if 24v pulses then connect HSO-0 to step- and connect 24vdc to step + if it accepts 5v pulses connect HSO-0 to step - and connect 24vdc with 2.2 k ohms resister in series to step + check this may solve your problem Link to comment Share on other sites More sharing options...
