jorg1n Posted September 30, 2010 Report Share Posted September 30, 2010 Hello, I've never used this kind of module, but I intend to try. I usually use microcontrollers (PIC), but for my new application, I will wish to use a V130. But I still have some questions: The development of a Communication Ethernet TCP / IP is it easy to implement? Thank you in advance Quote Link to comment Share on other sites More sharing options...
Emil Posted October 2, 2010 Report Share Posted October 2, 2010 It's more than "easy". For a person, which already has some expereince, this procedure takes less than one munite. I guess takeing a look on relevant Help files and examples to see the way will take about 3-5 minutes for a newbee. Quote Link to comment Share on other sites More sharing options...
