Rhulani Marhanele Posted June 11, 2012 Report Share Posted June 11, 2012 Hello, My name is Rhulani Marhanele from NCP Yeast and I am busy with the project which involves Allen Bradley L32E Control Logix PLC and Unitronics V350 OPLC. I am using DF1 Communication protocol – via Serial Port, guided by the attached document (find attachment) and the Visilogic V9.3.1 Help file. Software: For V350 = Visilogic V9.3.1 For L32E = RSLogix 5000 I’ve got in to a point where I can communicate between these two PLCs and I can send/Receive the following data types: Integers: MI and XI Floats: MF I am currently struggling to Send/Receive the following data types: Booleans: MB and XB Timers Counters May you please assist me to configure the PLCs to achieve the transfer for the rest of the data types (Bool, Counter and Timer). I will appreciate your assistance. Thanks.UNITRONICS V130 V350 V570 DF 1 COMMUNICATION (3).doc Quote Link to comment Share on other sites More sharing options...
Damian Posted June 11, 2012 Report Share Posted June 11, 2012 First thing is to definitely make certain you have the most recent OS in the V350. There was a bug in the DF1 block that caused abnormal behavior depending on what data and addresses were used. Second thing is a warning that the document you are referencing does have a few errors. It is definitely useful, but there are some inaccuracies. Unfortunately, I failed to properly take note of these back when I was doing this myself so I am a bit rusty on those details. There were also some address ranges that quite simply could not be accessed for whatever reason I was never able to figure out. If I get time I'll give it a try again a bit later. Good Luck Quote Link to comment Share on other sites More sharing options...
Damian Posted June 11, 2012 Report Share Posted June 11, 2012 See also this thread from the "old" forum http://www.unitronics.com/forum/topic.asp?TOPIC_ID=2115&SearchTerms=DF1 It may help with you MBs Quote Link to comment Share on other sites More sharing options...
Rhulani Marhanele Posted June 12, 2012 Author Report Share Posted June 12, 2012 thanks, this seem to make sense. I will perform the test today. i will post on progress. Quote Link to comment Share on other sites More sharing options...
