DonH Posted June 19, 2012 Report Share Posted June 19, 2012 Hi All, I have 4 V1040's in service, and for some reason when the PLC is powered down and then re-powered up it would loose the application, the only way to fix this, was to do a Download All & Burn. I never had to do this on the V570's Just wondering is there a problem with the V1040 or could something be causing my application to disappear? The battery is brand new and is good. Deke aka (DonH) Quote Link to comment Share on other sites More sharing options...
