dhuggins Posted August 3, 2012 Report Share Posted August 3, 2012 Hello, I just recently updated Visilogic to version 9.4 and also the O/S on my v1040. Then I went to my program I was working on and downloaded it. Everything was going along fine then bam my communications was lost. Now the screen is just flashing Starting PLC..... for about a second then it flashes the Fatal Error for a split second and goes blank. Then it repeats this indefinitely. I cycled power and took out the battery and it started back up doing the same thing. Next, I held my finger down on the screen and it went to a boot touch request and started the countdown to O/S timer. It starts at 10 and counts down. Once it gets to 0 the screen resets and starts flashing the same thing again. I need some help. I dont know what went wrong or how to get it out of this loop. I have windowsXP and my systems are all update as I completely deleted visilogic and did a fresh install of the new version. Help Please! Thanks, Dustin Quote Link to comment Share on other sites More sharing options...
Walkerok Posted August 3, 2012 Report Share Posted August 3, 2012 Contact your Unitronics seller. I beleive you need a replacement unit from reading some of the other posts in the forum. Keith Quote Link to comment Share on other sites More sharing options...
dhuggins Posted August 3, 2012 Author Report Share Posted August 3, 2012 Might I add that just before I updated my system I had the program up and running and was troubleshooting. Thanks, Dustin Quote Link to comment Share on other sites More sharing options...
dhuggins Posted August 3, 2012 Author Report Share Posted August 3, 2012 Contacted Customer Support on this issue and there is a problem with the touchscreen. They were very helpful and patient in finding a solution to the problem. Thank you Unitronics! Dustin Quote Link to comment Share on other sites More sharing options...
