I have an application I am converting from Allen Bradley code. In the Allen Bradley I am using the OSF block. This block has a storage bit and an output bit that retains state after the transition. I tried to use a -|N|- but the coil will not retain the state unless I make it a -(S)-. Then I have no easy way to reset it.
Is there a simple way to achive this same functionality in VisiLogic?
OSF Storage and Output Bits Operation
Rung State Transition Storage Bit Output Bit
true-to-false (one scan) bit is reset bit is set
false-to-false bit is reset bit is reset
false-to-true and true-to-true bit is set bit is reset
Ideas?
Andy
I can't delete this so I will just say I figured it out. I was hung up on the falling trigger and not setting a bit for the oneshot in my rung after. I was trying to just use the -|N|- when I needed to store it first since I needed to use it as an examine on and examing off in two branches. Works great now.
Register a new account
Sign in
Important Information
Confirm to continue.
