TyZoN Posted November 7, 2012 Report Share Posted November 7, 2012 Hi guy's I use lots of times vision series plc's for many applications.(communication, analog I/O, heat sensing etc.). But now i have a new project and i want to use Vision130-33-tra22 with a 360 puls shaft encoder and a servo drive NPN mode. My question is encoder and the servo motor can be moved at the same time? This mode is known as "Gearing" and generaly use at the "flycut" aplications. I fail do it and i wait your helps... Regards... Quote Link to comment Share on other sites More sharing options...
