jimbo Posted May 13, 2013 Report Share Posted May 13, 2013 Greetings, Am pulling my hair out trying to input the following equation: Q= C*sqrt( (h*pf/Tf) Where: C is a constant - 19214.5 H is an MI (need 3 decimal places(another issue) Pf is an MI (2 decimal places) T is an MI (0 decimal places) The calculation is for corrected gas flow using an annubar type device. having problem with the MI's regarding the decimals. Link to comment Share on other sites More sharing options...
Guest Jan N. Posted May 13, 2013 Report Share Posted May 13, 2013 Hi, As I understand, there is a need to use MF (memory float) instead of MI. Then You can get the decimal places and the resulting value will also be MF. After equation You can separate or round the resulting value if MI is needed. Jan Link to comment Share on other sites More sharing options...
