lomi Posted May 22, 2013 Report Share Posted May 22, 2013 Hello everyone, This is my first post here and I want to say hi to all of you good people. I am not so new to the PLC's, but i am new to Unitronic. So far i was wery found with V570, but now i must use jazz JZ10-11-R31. I have problem to communicate with electronic scale who send me constant signal on RS232 with next protocole : Start 1 Start 2 Sign bit1 bit2 bit3 bit4 bit5 bit6 end1 end2 <CR> <LF> W...........N........0 or -.............................................k........g I saw the demo aplication card reader and i managed to recive some value but when i change weight up and down the screen freeze. I stored: 87 -> SI141 (tryed 78) 103 -> SI142 (tryed 107) 14 -> SI143 15 -> SI144 0 -> SI145 1-> SI146 300-> SI140 trigger for storing is power up bit and i try Digital input and taster enter. Can you help me to establish this communication in order to countiniously recieve signal. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
