Marco Posted December 24, 2010 Report Share Posted December 24, 2010 Hi, Excuse me but I am French-speaking, and my English is catastrophic. 1 Question: What reserve Unitronics for de French-speaking? 2 Questions: I have V570 Master call any V570 Slave to GSM TC65, 1 call/day the nigh /Slave for Read 25 MI in Slave, It run OK, The communication Master –slave is Modbus serial. I want to us de GPRS, the communication GPRS between V570 Master Call and Slave Listener is OK, the two is connected. How to do for read 25 MI in Slave??? Thanks, Link to comment Share on other sites More sharing options...
Flavien Posted December 27, 2010 Report Share Posted December 27, 2010 Hi, Excuse me but I am French-speaking, and my English is catastrophic. 1 Question: What reserve Unitronics for de French-speaking? 2 Questions: I have V570 Master call any V570 Slave to GSM TC65, 1 call/day the nigh /Slave for Read 25 MI in Slave, It run OK, The communication Master –slave is Modbus serial. I want to us de GPRS, the communication GPRS between V570 Master Call and Slave Listener is OK, the two is connected. How to do for read 25 MI in Slave??? Thanks, Bonjour Marco Pour ce qui est des francophones, la traduction de Visilogic avance et Unitronics travaille à ce que plus d'éléments soient traduits, Au niveau de la communication MODBUS en GPRS, celle-ci fonctionne comme en ETHERNET, si vous arrivez a vous connecter au V570 esclave, il ne reste plus qu'a utiliser le bloc MODBUS IP => Lecture MIs MLs DWs. Je peut vous envoyer un exemple ou vous pouvez me contacter si vous voulez au 01.60.92.41.75 Cordialement, ------------------------------------------------------------------------------------------------------------------------------------ Hello Marco About the French-speaking, the translate of Visilogic is on his way and Unitronics works for increasing the number of translated elements, About the MODBUS communication via GPRS, it works as if it was in ETHERNET, if you are successfuly connected to your V570 slave, you only have to use MODBUS IP commands. I can send you an exemple or you could contact me if you want, Regards, Link to comment Share on other sites More sharing options...
