bahiaml Posted January 23, 2015 Report Share Posted January 23, 2015 I am creating a progam that performs a movement using the PTO utils and at one point held a parade. I'm using the PTO Stop configured as emergency stop, but after stopping the PTO move shows the message status number 3 ( Channel not initialized , or the outputs Vision not support function) and the stop block is no longer active .I tried to reset the PTO configuration after stopping but still did not work. Does anyone know what could be the problem ? The attached image shows the problem after the stop. Quote Link to comment Share on other sites More sharing options...
sunit Posted January 24, 2015 Report Share Posted January 24, 2015 Hi bahiaml Also give rising edge command to PTO set profile when you are using PTO move. Alos use the PTO set profile block while stopping the PTO. Below i am attaching the example how to configure it. Check it and do let me knowVisiLogic Project.pdf Quote Link to comment Share on other sites More sharing options...
bahiaml Posted January 26, 2015 Author Report Share Posted January 26, 2015 It worked!!! Thank you very much. Quote Link to comment Share on other sites More sharing options...
