erickkelvin Posted March 12, 2015 Report Share Posted March 12, 2015 Hello everyone, I have troubles connecting the v570 with the GPS from a fishing vessel. For interface with the GPS I'm using a Moxa TCC-100, and using FB protocol, without results. To test the GPS signal I connected the output RS232 from the Moxa to the PC serial port and using Hyperterminal and I got a signal from the GPS. $GPGLL,0907.623,S,07834.407,W,195745,A*2C $GPVTG,,T,84.9,M,0.5,N,0.9,K*59 $GPZDA,195745,11,03,2015,05,00*43 $GPGGA,195746,0907.622,S,07834.407,W,1,10,1.3,38,M,,M,,*7E $GPGLL,0907.622,S,07834.407,W,195746,A*2E and more.. Attached my program with gps signal, hope you can help me with some tips. Thank you for your time. GPS Signal fro mHyperterminal.txt EP Yagoda.vlp Quote Link to comment Share on other sites More sharing options...
linxchas Posted March 15, 2015 Report Share Posted March 15, 2015 Here is 2 years old topic were i posted sample code-NMEA-350 (link from my dropbox, If the file that you downloaded has an extension .zip, just replace it to .vlp. Than you'll be able to open it in Visilogic). http://forum.unitronics.com/index.php?/topic/1504-use-pointing-to-filter-data-from-rs-232-input/?hl=gps#entry5068 Hope it will help. Quote Link to comment Share on other sites More sharing options...
