milf os Posted January 28, 2016 Report Share Posted January 28, 2016 Hi I have an 3 installations. Each consisting of 8 x Jazz UA24, 2 x M91 RA22, 1 x JAZZ R16, 1 x JAZZ T41, 4 x CIAT water Chillers 2 x PROCON analogue input modules. They are all networked on RS485 using Specview SCADA package as MODBUS master. All the Jazz PLCs use the JZ-RS4 com port adapter All the Jazz controllers use the same Communication setup nets All the Jazz controllers are run from the same 24VDC power supply So that's the situation as it stands. My problem is that the JAZZ R16 on all sites has very flakey coms. It will occasionally come online after a restart for a short period of time then fall off again. The comms on all the other devices including all the other JAZZ PLCs is pretty solid. I have tried downloading the exact same program into a spare jazz UA24 and it communicates fine. So by deduction I would assume it is a hardware issue with the R16 specifically. Has anyone else had this problem and is there a way to fix it?? Thanks Quote Link to comment Share on other sites More sharing options...
