JAZZ10 over Modbus Gateway
Dear all,
I want to connect JZ10-T18 with MJ20-PRG module to Modbus Gateway, because I want to establish communication to the PC over Ethernet.
Gateway has Ethernet TCP port : 192.168.1.1 - Router_EthernetPort.bmp.
Gateway has RS232 port adjusted as you can see on picture Router_SerialPort.bmp.
Ethernet card on PC side adjusted like on picture : TCP_IP_settings.bmp.
Also, I configured UniOPC as you can see on picture : UniOPC_Settings.bmp.
You can see PLC program on picture : JAZZ10_prg.bmp.
When I connect OPC Client to the UniOPC and add Item "PLC1.STATUS" I get as result : "Communication Fail".
I am not sure what could be problem.
If somebody confirm me about PLC program is it ok?
Or maybe I need MJ20-RS module?
Tomorrow I will get MJ20-RS modul.
Also, pin out for the Gateway RS232 port is :
1 - RTS
2 - DTR
3 - TXD
4 - GND
5 - GND
6 - RXD
7 - DSR
8 - CTS
and I ceonnect to MJ20-PRG :
RS232 pin 1 to pin 6 MJ20-PRG
RS232 pin 2 to pin 1 MJ20-PRG
RS232 pin 3 to pin 3 MJ20-PRG
RS232 pin 4 to pin 2 MJ20-PRG
RS232 pin 5 to pin 5 MJ20-PRG
RS232 pin 6 to pin 4 MJ20-PRG
JAZZ10_prg.rar
Router_SerialPort.rar
Router_EthernetPort.rar
TCP_IP_settings.rar
Register a new account
Sign in
Important Information
