caitovic Posted April 19, 2016 Report Share Posted April 19, 2016 Hello, I'm working now with this type of PLC, and I can't download my program to the PLC by USB, can you help me with this i don't have a lot of information about this PLC, if you can tell me something more about how can I Download my programs for them I'll be glad. Thank you. Quote Link to comment Share on other sites More sharing options...
cmc Posted April 20, 2016 Report Share Posted April 20, 2016 Hi, The easiest way I've found is to use an Ethernet connection all you need to do is check the IP address in the network section of the Uniapp menu, then type that into the ethernet section of the discovery window of Unilogic. For USB make sure your computer is connected to the PLC and then click the USB option in the discovery window, you may need to refresh the connection. Also the window I'm talking about is accessed by pressing 'PC - PLC Communication' in the PLC tab of Unilogic Hope that helps. Quote Link to comment Share on other sites More sharing options...
