UdoB Posted December 28, 2016 Report Share Posted December 28, 2016 Since hours now I try to create an Input field for numeric values. I use Vision 1040, it is a touch Panel. When I use Variable : Numeric an choose Keypad entry, I expect a keypad appears after touch this field. But it doesn't. Thanks for help - Udo from Germany. Dok_keypad_entry.docx Seems to be fixed by myself and info from Forum: I had an Functionblock "Show Alarm" called every cycle. i disabled this call and now ist running. 1 Quote Link to comment Share on other sites More sharing options...
