Addressing Integers at the Bit level
Damian
I believe TM originally requested this a long time ago, but I thought I might throw it out there again.
It would be nice to have the ability to address INT and DINTS at the bit level.
So just as we may be assigning a normally open contact "MB0", I would also like to assign a contact say "MI8.5" or "DW2.17".
Using TEST BIT is clunky, time consuming, and takes up too much rung area, and while in Online mode is not as easy to see if it is testing OFF or ON.
Even then it is only converting to a BIT operand with then needs also to be referenced again somewhere else.
