Bassla Posted May 23, 2019 Report Share Posted May 23, 2019 Hello, I'm using VisiLogic software for programming V350 and this is my problem: For my project I use High Speed inputs to know the position of an electrical jack. The value is then stored in DW50. When the V350 is powered off and then on, DW50 become 0 and I lose the positioning of my jack. Do you know if there is a solution for fixing this problem? Like a word which is memorized. Thanks for your answers Quote Link to comment Share on other sites More sharing options...
Isakovic Posted May 24, 2019 Report Share Posted May 24, 2019 Copy DW50 into some other location every scan. Then copy back at startup. 1 Quote Link to comment Share on other sites More sharing options...
Bassla Posted May 25, 2019 Author Report Share Posted May 25, 2019 Thank you for your answer, it works Quote Link to comment Share on other sites More sharing options...
