jojo Posted May 12, 2011 Report Share Posted May 12, 2011 I have a problem with connection V1040 with absolute encoder and some IO-box through the CANopen. I make a simple program with port initialization, setting of Unit ID and CANopen configuration. I test som other FB's, but it's not working. In info-mode on PLC in the Canbus menu is correct baud-rate, but in protocol type is NO PROTOCOL. Where I make a bug? In attachment is this program. Pleas help me. Quote Link to comment Share on other sites More sharing options...
bc_fred Posted May 30, 2011 Report Share Posted May 30, 2011 Hey jojo: I'll jump in since no one else came to your aid. In Info-Mode, when you're in the CANbus screen, initially the selection is "NO PROTOCOL". Touch "NO PROTOCOL" to select it (it will become darker). Then, use the yellow UP and DOWN arrows at the right to change the protocol selection. This works also for the baud rate. Info-Mode is our friend, really handy. Quote Link to comment Share on other sites More sharing options...
